O2 simms same as deleting rear O2s with LS1edit?
Are the rear O2 ONLY for detecting bad cats, or do they actually have some impact on the way the engine runs. Example, does the engine try to run richer or leaner if it THINKS the cats are bad?
Thanks for any info!
Tommy <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
....so much for any compentitive pricing pressure on LS1Edit...
Reply-To : <tc@tunercat.com>
To : "'Gillbot'" <xxxxxxxxxxxx>
Subject : RE: Tunercat Software
Date : Mon, 17 Feb 2003 09:19:40 -0800
Hi Gillbot,
Thank you for your e-mail regarding the C.A.T.S. Tuner program.
We are working on an OBDII version of the Tuner program now that will support the LS1's. We hope to have this version available later this spring.
If you have any other questions, or would like additional information, please do not hesitate to contact us.
Best Regards,
TC
<strong> Rear O2's are only used to report catalyst efficiency when PCM tests for it. I didnt know LS1edit could delete rear o2's? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">With edit you can delete the SES codes it would throw if getting "bad" reading from the rear O2s.
