Power Loss
Old Feb 22, 2006 | 07:02 PM
LS1Queen's Avatar
Default Power Loss
After my car was tuned about 4 months ago it ran 7.0 at 99mph in the 1/8 mile afr was 13.1 at that time but now the car has slowed to 7.2+ at 95-96 mph and the motor is running at 11.4 afr at WOT What would make the tune change? How long is a tune good for?
Old Feb 22, 2006 | 07:40 PM
jimmyblue's Avatar
Moderator
Did your tuner eliminate COT protection? If not the
car can kick into a fuel-dump mode any time you
get to romping on it. If you have picked up some
jacked fuel trims that could also push WOT fueling
around. Scan it and see, if your trims look tight then
I would suspect the COT kicking in (unless you know
otherwise, for sure).
Old Feb 22, 2006 | 07:48 PM
LS1Queen's Avatar
Not sure jeremy from rev extreme tuned it so i would have to ask him but the fuel trims are not that great Bank 1 seems to be good but bank 2 will be way - and then you can reset them and it will go way + only at idle at 2000 rpm they both are rihgt at 0 also at idle the afr jumps between 14.8 to 17.4
