Trany swap
The PCM needs a crank relearn to be done prior to being used in your car. Without it the car will barely run.
After this is done, then you can flash your program to the computer.
You are going to have to ensure that the tranny will properly communicate with the PCM first, then you will have to change your shiftpoints to coincide with the different gearing of the tranny.
Good Luck,
Kevin
