how do you put car in open loop?
as for why it's running at 500rpm... does it do this forever or only on initial start? what's your idle set at for cooler temps (startup)?
These cars run open loop at startup normally so shouldn't be any different at startup (assuming you just set closed loop enable to a high temp like 290 or so) ... not sure of the affects of unplugging an O2 sensor (or rather if there are any other side effects as I've never tried it)
