SES light came on the went off
This morning the light came on at start up. Less than 2 miles from home it went off.
The car was at the dealer for an SES light. They found code P0130 'H021 Circuit Sensor 1' and replaced the 'AIR Pump Vacuum Valve'. It's located above cylinder 7.
What's up? Why does the light go off on its own? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
It is a pending DTC and will clear itself after three successful operating cylces AFTER the cycle that originated the code.
The random misfire code P0300 and P0305 (for cylinder #5) if they were thrown, would also clear after the same 3 successful operating cycles.
I wouldn't worry about it.
<small>[ March 25, 2003, 11:26 AM: Message edited by: CMNTMXR57 ]</small>
A dyno operator once told me it is good to re-set the PCM about every oil change. He said it was like re-booting a PC. He described the method I've seen on the boards. Any truth to that?
1. Turn key on but don't start car.
2. Pull PCM BAT and PCM IGN fuses in engine compartment.
3. Wait a few minutes.
4. Turn ignition off.
5. Replace fuses.
I dunno if I'd recommend doing it every oil change though! Part of it is allowing the PCM to learn your driving style. Why constantly reset it to re-learn it (as well as the idle) over again?
I have definitely learned some PCM stuff here. Thanks! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Maybe one day I'll mess with a MAF translator or even LS1Edit. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
1 is a DTC (Diagnostic Trouble Code) which will trigger the MIL (Malfunction Indicator Light) or in common speak, the SES light. The DTC depending on what it is, will more than likely need to be physically cleared via Auto-Tap, EFI Live, or a GM Tech2 scanner. They most commonly will clear themselves out and turn off the SES light on their own. However, that usually clears after 40 successful operating cycles AFTER the system pass a system test (for that DTC). So even if it was a once in a lifetime thing, it'll be quite awhile before it clears. Let alone those that it will repeatedly and intermittently generate the code. In that case the light would never go off. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
2 is called a "Pending DTC" These are potential DTC's that "could" be set in the future or could be a domino like effect from a regular DTC. Or simply just a pending non-essential random code. These codes (as well as some DTC's in #1 above) will clear after 3 successful operating cycles after the initial failed cycle. Pendings can also be cleared via a scanner listed in #1.
All in all, some regular DTC's, will clear also after three successful operating cycles after the failed cycle. It depends on what the code is.
