Secondary AIR injection malfuction
I heard you dropped quite a bit of coin with those jackasses over @ Xtreme as well man. Sorry to hear, seems to be the norm for them.
If it set once, it will set again, just give it time. They obviously missed the code.
<strong> If the deletion of codes isn't the problem, here is the troubleshooting I posted in this thread for P0410 Secondary A.I.R. Injection.
https://ls1tech.com/ubb/ultimatebb.p...;f=23;t=004456 </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks for the information <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Thanks for posting under my topic <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
https://ls1tech.com/ubb/ultimatebb.p...;f=23;t=004456 </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Holy ****...that's alot to read <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> I hope I can figure that out. I know my first problem is going to be the fact that I don't have a scantool. <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
<strong> It just looks big when I have to format it for a UBB. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
The only problem with the GM instructions is that they are geared towards a service department that has Tech2 scanners readily available so a Technician can easily grab one and use it. A Tech2 can command things on/off, on at 25%, 50%, 75%, 100% etc in order to aid in diagnosing. An EGR system is a perfect example of this. You can command it on in those percentages which will show up as "Desired EGR pintle position" and then compare to what the EGR pintle position is actually doing in order to determine what is failing in the system. That's just one example.
Don't feel soo bad, my 96 Monte Carlo throws a P0410 Secondary AIR code once a week and that one is a 40+ step process. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> I just have not got around to messing with it. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Well, I don't have a tech2 so I'll have to just live w/the light until I get my own LS1Edit copy and just delete it like it should've been in the first place. Thanks for info though!
