Do you have to disconnect the MAFT when resetting the pcm?
Pathological Modifier
Re: Do you have to disconnect the MAFT when resetting the pcm?
The MAFT will not interfere with resetting the PCM. I pull the PCM BAT, then turn the key to ON (not start) for about 20-30 seconds, then turn it off and put the fuse back in. Should be as simple as pie!
Ryan K. <img border="0" alt="[USA]" title="" src="graemlins/patriot.gif" />
