Question about Custom Edit tuning + MAFT
Old Mar 28, 2003 | 10:13 AM
NHRATA01's Avatar
Default Question about Custom Edit tuning + MAFT
Ok, I plan on bringing my car to a sponser for some custom dyno tuning with Edit. Right now I'm running a MAFT to keep the LTrims at 0, and WOT mixture from being pig rich. Only seeing about 24-24.5 degrees at WOT (no KR), and have a decent amount of mods, so this is why I'd like to get it tuned. My question is, should I turn my MAFT settings back to 0 for base and WOT? My LTrims would the go up to about +10. Or should I leave it as is with base set at 10% and LTrims at 0, since isn't this ideal for tuning?
Old Mar 31, 2003 | 08:29 AM
NHRATA01's Avatar
Default Re: Question about Custom Edit tuning + MAFT
TTT anyone? Basically if you had a MAFT and then got custom tuning, did you pretty much do away with the MAFT?
Old Apr 1, 2003 | 08:52 AM
Dave@Ramchargers's Avatar
if you have the car tuned correctly you will not need a MAFT.. However large changes in weather or mod changes may need to be fined tuned.. thats when the MAFT would be usefull again to you
Old Apr 1, 2003 | 01:22 PM
NHRATA01's Avatar
Right, that is a good point, and I do plan on keeping the MAFT.
My main question is though, when I take the car for Edit tuning should I zero out my MAFT settings (especially base settings) or leave them as is. I didn't think a shop could really tune LTrims with dyno tuning, and I thought ideally you want your LTrims at 0 prior to doing any tuning.
Old Apr 2, 2003 | 08:27 AM
0 it out... let them tune it first.. if they cant get your ltrims in check then they arent really that good at tuning
