Adjusting timing tables to 98 spec on an 02
Old Mar 29, 2003 | 03:41 PM
jaywoo's Avatar
Default Adjusting timing tables to 98 spec on an 02
I've been reading a bunch about this. Here's the problem I'm running into. I open up my timing table, then click on "read file" and open up the file from a 98. However, that table is completly messed up when viewing it like that. I mean just crazy numbers. If I open the 98 file by itself, it's fine. So, I can't copy the table and put it in my table. I guess I could do it by editing each cell individually, but that's going to take some time. IS that my only choice, or am I being a bone head and doing something wrong? Thanks!
Old Mar 29, 2003 | 04:19 PM
Tim Sloper's Avatar
Default Re: Adjusting timing tables to 98 spec on an 02
Unfortunately you will have to manually edit each cell. LS1Edit will be looking for the table at the 02 locations which is why you are seeing screwed up values.
Tim
Old Mar 29, 2003 | 04:38 PM
jaywoo's Avatar
Yeah, I just exported the readings into Microsoft Excel, and I noticed the 98 table stops at 1 Gms/Cyl, but the 02 table goes all the way to 1.2 Gms/Cyl. Dangit! Thanks!
