Would resetting the computer...
Old Mar 29, 2003 | 08:51 PM
99BackNBlackZ28's Avatar
Default Would resetting the computer...
Cause things that were done via LS1Edit to reappear? For instance, would my EGR and AIR codes show up if I were to reset the computer?
Would resetting the computer enable my car to relearn fuel tables? I'm having issues with mileage on the car (maxing out at 190mi per tank). I think that's horrible gas mileage. I do nothing but city driving, have an m6, but never go fast enough to use 5th or 6th gear.
TIA
Old Mar 29, 2003 | 08:58 PM
LS1 PWRD's Avatar
Default Re: Would resetting the computer...
What ever you changed with LS1-Edit will still be there after a reset.
Old Mar 30, 2003 | 04:32 AM
Predator's Avatar
From what I can see, resetting the computer causes idle relearn, and puts your smog tests in a 'not completed' state until all the tests are run again.
Old Mar 30, 2003 | 08:03 AM
niphilli's Avatar
LS-1 edit modifications should still be there. There will be an idle re-learn, and your fuel tables will probably be messed up for a while. My car goes nasty rich for a while after reset and it is LS-1 edited.
-Nick
