MAFT Tuning (Problem?)
Old Mar 30, 2003 | 01:20 AM
GixxerSS's Avatar
Default MAFT Tuning (Problem?)
I've attached a MAFT because my car is running lean and pinging above 3500 RPM. I had it set a couple of different ways, 1. lowest percent rich across the band and 2. 5% rich at WOT. Both bog down the idle to around 500 RPM. Am I doing something wrong? The car wants to stall. I have a 99 SS with Whisper lid, Powershot filter, Composite MAF ends, FTRA. Any help would be appreciated.
Old Mar 30, 2003 | 01:58 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Re: MAFT Tuning (Problem?)
The car needs to relearn each change you make so a bog is normal.
If you don't have A-tap to tune the MAFT in I would suggest base setting on 0 and WOT setting set to 6%rich to start with.
Old Mar 30, 2003 | 02:59 PM
JamRWS6's Avatar
How did u get 5% rich at WOT....it goes in increments of 2% on the WOT switch (ie 2% 4% 6%)
The base goes in increments of 5%
Are u adjusting the correct switch?
Old Mar 30, 2003 | 05:13 PM
GixxerSS's Avatar
Sorry, I had the Base & WOT mixedup in my head when I posted. Thanks for the replies guys, I'll give it another try and run it for a while. Hopefully the idle goes back up from 500 RPM <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 30, 2003 | 06:31 PM
JamRWS6's Avatar
If u want a refrence point....
mine is a 02 MN6 with a lid, bellows and MAF Ends
I'm running it 10% rich base which leaves my LTFTs just slightly negative.
My WOT is set at 2% Lean which reads about 887 mv on my 02s.
Old Mar 30, 2003 | 10:06 PM
GixxerSS's Avatar
Thanks for a tips guys <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Apr 1, 2003 | 08:49 AM
Dave@Ramchargers's Avatar
How do you know you are running lean?
And you shouldnt mess with the base unless you know what your Trims are..
Old Apr 1, 2003 | 11:08 AM
JamRWS6's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Dave@Ramchargers:
<strong> How do you know you are running lean?
And you shouldnt mess with the base unless you know what your Trims are.. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I agree....if you don't have access to Atap or a similar scanner don't try and guess.
Old Apr 1, 2003 | 10:50 PM
GixxerSS's Avatar
Well, nothing ventured, nothing gained. I tried JAMRWS6's recommendations but set it to 5% to start. The car feels much smoother and better throttle response <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> So far so good on the idle. Looks like I found the power I lost. I have a little hint of a ping at 5k but I have a few more mods ready for install then I'll try it again. A scanner is definitley in order though. Thanks for the responses guys.
