Possible to disable TCS via Edit??
Old Mar 30, 2003 | 11:00 AM
z28man's Avatar
Default Possible to disable TCS via Edit??
Can I disable my tcs with edit??? If so how?
Old Mar 30, 2003 | 05:36 PM
Predator's Avatar
Default Re: Possible to disable TCS via Edit??
The only way I know is by "loosening-up" torque management by increasing the max torque number. Ken Kelly, at Carputing, said that that number shouldn't exceed 639 lb/ft, though.
Old Mar 30, 2003 | 06:15 PM
NoGo's Avatar
SLP sells a great little mod that inverses your TCS system. The system is always off (even when you start the car), and you press the switch to turn TCS back on.
Old Mar 30, 2003 | 09:00 PM
Classic's Avatar
If you want to save the money - just pull the TCS fuse in the engine compartment drivers side fuse box. I do it at the track to keep from embarassing myself and attempting my burnout with TCS on <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> That might not be the solution you are looking for - I mean that dissables it completely. If you want to still be able to switch it on and off on the fly - get the SLP switch.
Old Mar 31, 2003 | 03:57 AM
Predator's Avatar
Geez, I have the SLP TCS module too, but I didn't think that that was what z28man meant. The SLP module doesn't "disable" traction control, it just reverses the switch at startup. If that's what you're looking for, it works like a charm.
<img border="0" alt="[USA]" title="" src="graemlins/patriot.gif" />
