Battery HELP !!!!!
Old Mar 30, 2003 | 09:09 PM
BLK99SS#3's Avatar
Default Battery HELP !!!!!
I have a 99 Camaro SS and I don't drive it everyday but I try to start it at least once a week, but for some reason every time I try to start it the battery is dead, I can't find anything being left on but the battery is dead every day. Does anyone know what it could be???????
Old Mar 30, 2003 | 09:30 PM
01redws6ta's Avatar
Default Re: Battery HELP !!!!!
Are there any lights staying on in your car? Is the battery original? Battery may have a bad cell too. If no lights are on, have your battery tested. If battery OK, have a parasitic battery draw done on your car. Anything more than 20 milliamps draw would be considered too much.
Old Mar 30, 2003 | 09:41 PM
LASTLS1's Avatar
6 Second Club Moderator
My battery went bad in 11 months, only 3000 miles on the car. Just replaced with new, thanks to warranty.
Old Mar 31, 2003 | 06:39 AM
DaveSchott's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 01redws6ta:
<strong> Are there any lights staying on in your car? Is the battery original? Battery may have a bad cell too. If no lights are on, have your battery tested. If battery OK, have a parasitic battery draw done on your car. Anything more than 20 milliamps draw would be considered too much. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">had the same thing on my car, replaced the battery, same thing so did the test. test indicated the battery was bad (what are the odds of having 2 replacement batteries from 2 sources being bad??) and won't know if the new battery is the cure until its back on road. The helms manual has the parasitic test info in it, you can do the test yourself with the right multimeter. i did it. i even pulled the alternator thinking the the regulator malfunctioned.
<small>[ March 31, 2003, 06:43 AM: Message edited by: DaveSchott ]</small>
Old Mar 31, 2003 | 02:24 PM
Team ZR-1's Avatar
Even with the car off the PCM is still drawing up to a 1/2 amp of current per day so it is always better to have a battery tender hooked to battery to supply more voltage into the battery then what the car's electronics are using when car is sitting for days.
Over time low votage in battery could cause one of the battery cells to weaken or go bad.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BLK99SS#3:
<strong> I have a 99 Camaro SS and I don't drive it everyday but I try to start it at least once a week, but for some reason every time I try to start it the battery is dead, I can't find anything being left on but the battery is dead every day. Does anyone know what it could be??????? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
<small>[ March 31, 2003, 02:26 PM: Message edited by: Team ZR-1 ]</small>
Old Mar 31, 2003 | 07:22 PM
BLK99SS#3's Avatar
I did buy a new battery and it still happened so I assumed it's not the battery but I will check a couple more things. Thanks for all the advice, it helped alot.
