hot start problem - how / where to adjust??
well i have the typical "hot start" problem w/ my new cam. starts great when cold, but once warmed up, you gotta give it a little go peddle to get it to start. otherwise it just cranks. what table in LS1 edit needs adjusted to help/fix this? i also noticed my IAC counts are up to about 70 or so. do i need to adjust this (drill the T/B blade out) first before attempting to fix the hot start problem?
If your IAC count is not slammed to its max
value, then do not drill the hole. Don't know
the max value, but I bet 70 isn't more than
halfway to it.
Did you try and do the idle relearn? Maybe it
will figure it out for itself, if you make it.
Do the relearn while hot?
halfway to it.
