Timing? Where to set it
Old Mar 2, 2006 | 11:55 PM
C.J.'s Avatar
Default Timing? Where to set it
How much timing would you say a bolt on LS1 should be set to? 28 degrees? more? less?
Old Mar 3, 2006 | 07:37 AM
ace68's Avatar
28 is not bad about as much as you want to go. Any KR?
Old Mar 3, 2006 | 07:59 AM
Assassin's Avatar
if your tuning w/a wideband, pick an afr, get the right amount of fuel then basically as much timing as possible w/out kr... and if you go too far it will kr...
Old Mar 3, 2006 | 08:55 AM
slow trap's Avatar
i could only get my cam only setup to 26* without kr,that was with 13.0-13.3 afr and on 93 octane.
Old Mar 3, 2006 | 08:58 AM
ace68's Avatar
Slow Trap you have stock heads on the car?
Old Mar 3, 2006 | 01:33 PM
C.J.'s Avatar
Sounds good guys, thanks for the input
Old Mar 3, 2006 | 02:09 PM
slow trap's Avatar
when i had stock heads i could only get 26 *,now it's 28,i think anyways.
Old Mar 3, 2006 | 02:16 PM
horist's Avatar
also when adjusting your timing keep in mind this is peak timing ... you don't want to set it 28* across the board. Generally you want lower timing around peak torque (highest cylinder pressures) and most timing around peak horsepower
