How does this data look? New to predator.
Old Apr 10, 2003 | 04:42 PM
BLK02WS6's Avatar
Default Re: How does this data look? New to predator.
I would highly recommend that you take it to a dyno and get a wideband on it! It looks a little lean from the data and you can't count on the live data being very accurate!
It is worth the money to get it dynoed with a wideband - ask me how I know - I didn't get the LS6 in my sig cause I had extra money to spend...run one too lean for long and it will be toast!
Old Apr 11, 2003 | 12:59 AM
004mula's Avatar
Default How does this data look? New to predator.
Hi,
First time using this thing so here are some readings. I did get a P0101 error code. What does that mean? I have a ported MAF (not de-screened). MAF-T, TTS Longtubes and M6 transmission.
Any help would be appreciated:
ST= 0.3-4.16%
LT= 13.25 %
21.8 deg spark at idle, 30 deg at WOT
KR= 0 deg at idle and 3.14 deg at WOT
O2's
75-815 mV Bank 1
115 mV Bank 1
95-805 Bank 2
115-130 Bank 2
I am using 4 02 sensors and no sims. Also, how can you tell which is the front and rear O2 from the data?
Thanks for the help
Ian
