LS1Edit Wizards, simple question...
Old Apr 10, 2003 | 05:20 PM
99BackNBlackZ28's Avatar
Default LS1Edit Wizards, simple question...
I thought I had all my AIR codes deleted via LS1Edit, but I got an SES light. I had a buddy slap a scanner on it, and it read "Secondary AIR injection malfunction."
Was this simply because it wasn't deleted in Edit? After Edit, I pulled the fuse out for the AIR pump, but never actually removed the AIR pump itself...would this cause any conflicts?
Old Apr 10, 2003 | 11:21 PM
Default Re: LS1Edit Wizards, simple question...
ttt
Old Apr 11, 2003 | 08:09 AM
Camaroholic's Avatar
Did the scanner tell you what code?
There's a code, something like 1415 or somewhere "up high" (above 1000), that is also AIR. Did you get all of them? Sounds like you didn't.
See if you can get the actual code number, and then go to LS1Edit and find that same code. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Worked for me. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
-Andrew
Old Apr 12, 2003 | 12:29 AM
I asked the question in relation to the fuse for the AIR pump itself because I don't have LS1Edit.
