Diagnostics Port not working????
Old Apr 10, 2003 | 07:11 PM
Gimp98TNT's Avatar
Default Diagnostics Port not working????
Need some help guys, I finished putting my car back together and now the diagnostics port wont work. Tried both my scanmaster and HPP. I had to rewire the blue connector on the PCM, and i rewired my entire nitrous system I'm sure one of those things has somthing to do with it. But i have no idea where to start on this.
TIA
Jim
Old Apr 10, 2003 | 07:46 PM
theblur98ss's Avatar
Default Re: Diagnostics Port not working????
Check the fuses. I think it's the gauges fuse in the box inside the driver's door. I had that happen to me after blowing a fuse from my nitrous setup.
Old Apr 10, 2003 | 11:22 PM
CMNTMXR57's Avatar
Scan Tool Does Not Communicate w/Class 2 Data Line
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">
Step 1
Use a DMM in order to measure the voltage between B+ and DLC terminal 5.
Is the voltage within the specified range?
Specified Range = B+ (9-14 V)
Yes: Go to Step 2
No: Go to Step 3
Step 2
Inspect for a proper connection of the scan tool to the DLC.
Is the connection OK between the scan tool and the DLC?
Yes: Go to Step 6
No: Go to Step 7
Step 3
Does the instrument cluster display work?
Yes: Go to Step 4
No: Go to Step 5
Step 4
Repair the poor connection or open in circuit 451 between the DLC and S215.
Has the repair been made?
Yes: Go to Step 17
Step 5
Repair the poor connection or open in circuit 451 between S215 and G110.
Yes: Go to Step 17
Step 6
Use the scan tool in order to establish communication with the PCM on a different vehicle.
Can communication be established with the scan tool?
Yes: Go to Step 8
No: Go to Step 9
Step 7
Repair the poor connection between the DLC and the scan tool.
Is the repair complete?
Yes: Go to Step 17
Step 8
1) Reconnect the scan tool to the DLC.
2) Turn the ignition switch to RUN.
3) Use a scan tool in order to establish communication with the Powertrain Control Module (PCM).
Can the scan tool communicate with the PCM?
Yes: Go to Step 10
No: Go to Step 11
Step 9
Determine if the scan tool is malfunctioning.
Refer to the scan tool instruction manual for additional information.
Is the action complete?
Yes: Go to Step 17
Step 10
1) If malfunction is not present or intermittent, inspect the PCM connector for a poor connection, short to B+, or short to ground in CKT 1807.
2) Repair as necessary.
Yes: Go to Step 17
Step 11
1) Turn the ignition switch to the OFF position.
2) Disconnect the PCM connector C1 (V6 VIN K) or C2 (V8 VIN G).
3) Use a DMM in order to measure the resistance between the DLC terminal 2 and the DLC terminal 5.
Is the resistance the same as the specified value?
Specified Velue = Infinite
Yes: Go to Step 12
No: Go to Step 13
Step 12
1) Turn the ignition switch to RUN.
2) Use a DMM in order to measure the voltage between the DLC terminal 2 and the DLC connector terminal 5.
Is the voltage less than the specified value?
Specified Value = 1 V
Yes: Go to Step 14
No: Go to Step 15
Step 13
Repair the short to ground in CKT 1807.
Yes: Go to Step 17
Step 14
Check continuity in circuit 1807 between the DLC terminal 2 and the PCM connector C1 terminal 59 (V6 VIN K) or connector C2 terminal 58 (V8 VIN G).
Is there continuity?
Yes: Refer to PCM
No: Go to Step 16
Step 15
2) Repair the short to voltage in CKT 1807.
Yes: Go to Step 17
Step 16
Repair the poor connection or an open in CKT 1807.
Yes: Go to Step 17
Step 17
1) Ensure that the ignition switch is in the OFF position.
2) Reinstall connectors/components removed.
Yes: Go to Data Link Communications System Check</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Old Apr 10, 2003 | 11:57 PM
XLR8NSS's Avatar
Adkoonerstrator
I had that happen. Check the cigarette ligher fuse. If it's blown the diag. port won't work. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
