running lean...why?
Old Apr 12, 2003 | 02:55 AM
SSactionLs1's Avatar
Default running lean...why?
at the dyno i was at 14.7 a/f ...i thought with the headers id be rich if anything....a MAFT is on the way but can some one tell me why my mods will cause a lean condition??.. im confused..unless my TNT ring and bellows have a hole
Old Apr 12, 2003 | 08:31 AM
BLK02WS6's Avatar
Default Re: running lean...why?
Probably MAF ends.
Old Apr 12, 2003 | 04:30 PM
NoGo's Avatar
ditto on the MAF ends.
Vacuum leaks actually have a tendancy to make the car run richer at WOT. The vacuum leak jacks up your LTerms. The car adds your Lterms onto the WOT fueling, and you end up richer.
Good Luck,
Kevin
Old Apr 12, 2003 | 07:02 PM
speedy101's Avatar
What do you mean MAF ends?
thanks,
chris
Old Apr 12, 2003 | 08:47 PM
Slowhawk's Avatar
LS1Tech Sponsor
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by speedy101:
<strong> What do you mean MAF ends?
thanks,
chris </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Whisper MAF ends in your sig <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Did you verify the dyno A/F was correct?Sometimes when the sensor is going the A/F will start reading higher.
Old Apr 12, 2003 | 08:57 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Slowhawk:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by speedy101:
thanks,
chris </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Whisper MAF ends in your sig <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Did you verify the dyno A/F was correct?Sometimes when the sensor is going the A/F will start reading higher. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">how the hell do i check if the dyno is right? <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Apr 12, 2003 | 10:15 PM
Slowhawk's Avatar
LS1Tech Sponsor
You'd now if the next car is lean and so on.I had this happen last year,my car showed lean,then the next car was leaner,then the A/F died after that.
Just a thought.
Old Apr 13, 2003 | 12:38 AM
i can smell the gas in the exhuast.. <img border="0" alt="[bomb]" title="" src="graemlins/gr_bomb.gif" />
Old Apr 13, 2003 | 09:46 AM
speedy101's Avatar
the connector?
