130 mph /service engine soon ?
<small>[ April 12, 2003, 08:05 PM: Message edited by: GM ]</small>
high spark advance without some power enrichment
was giving me KR on deceleration. If you were
decelerating for a long while, maybe you logged
enough knocks to make the computer think you
had a problem. It might even go so far as to put
you into the "bad gas" program.
Deceleration is the highest spark advance region.
Max vacuum, min load / throttle. The IAC's control
of total airflow run-down is still providing some
significant cylinder charge and I bet you just
have too much spark for the fuel provided to that
set of conditions.
(factory/SLP +10HP CME) but have SLP "OEM"
Blackwing lid, SLP 85mm MAF and home-ported
TB. 13.6 sec 1/4 with negative weight
reduction (50lb of video gear in the trunk).
I haven't taken the PE any further than this,
1% was enough to shut up KR but I'd like to
see how far it goes before it stops netting
further improvement.
