New Timing Table Values, What Do You Thin?
Old Apr 16, 2003 | 07:13 PM
DailyAluminumBlock's Avatar
Default New Timing Table Values, What Do You Thin?
Guys, I just changed my timing table values into a columnised format. i.e. the 5200 and up below (more than) .60 gms/cyl is 28 degrees. 2800 is is is 28 from .60 gms/cyl all the way down etc.
My question is the rpm value before 2800 is like 18 degrees .60 gms/cyl and down, should I try more advance there also?
Posted by NoGo:
"28 29 30 30 28 26 24 28 28 28 28 28 28
The 26 would be at 4400 rpm, and the 24 would be at 4800 rpm."
Old Apr 16, 2003 | 07:17 PM
Default Re: New Timing Table Values, What Do You Thin?
A better example would be
2800 rpm 5200 rpm
.60 gms/cyl 28 28
.70 28 28
1.00 28 28
etc. 28 28
Old Apr 16, 2003 | 10:18 PM
Slowhawk's Avatar
LS1Tech Sponsor
I actually run 28 across the board to start.From 2200-7000 at .60 down and blend the other timing value's into it.Like under 2200 and above .60.
Old Apr 16, 2003 | 10:29 PM
Cool, but why don't you reduce youre timing at peak torque. don't you get KR.
Old Apr 17, 2003 | 09:12 AM
Slowhawk's Avatar
LS1Tech Sponsor
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DailyAluminumBlock:
<strong> Cool, but why don't you reduce youre timing at peak torque. don't you get KR. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No I don't get KR.My car runs 28 degree's so far.My friends is running 30 up to 5200rpm then 32 higher up the range with no knock.
Old Apr 17, 2003 | 09:25 AM
I might try even more advance then. Thanks.
