help with po121
i installed a 228/230 .573 .571 112lsa comp cam and the car isnt running like it should even after tuning. the only code currently thowing is 106, but i was throwing 101 and 103 as well. if you could please email me the process for fixing this
If NO MAP sensor or TP sensor DTCs are set, the engine has run more than 10 seconds, the engine IS warm, verify IAC is between 0 - 255 counts, the MAP is less than 55kPa OR the MAP is greater than 65kPa and the MAP is steady-- if all this is good, then the predicted throttle angle of the sensor does not match the actual throttle angle.
