question about adding fuel in Edit
Should I change any settings in Edit to add fuel since I am running to where it's adding fuel to be stoich?
Is the injector flow rate table what get's changed?
Pulse rate?
Is changing the PE to 65% instead of 90% going to cause me to go lean?
I am planning on getting some 42 Lb RC injectors for it, but I don't wanna blow it up till then.
I already have a tune # for the larger injectors(flow rate table changed)
Thanks for any help! Sam 2000 5.3 truck intercooled ATI P-1SC
