ses light, another 02 problem
Old Mar 10, 2006 | 02:09 PM
josh1107's Avatar
Default ses light, another 02 problem
i had posted this earlier, but after i replaced the 02 sensor, bank 2 sensor one, front passenger, the car ran fine. 70ish miles later(about 3 weeks) the ses light came back on. read the same as before. ckt slow response and insufficient switching. maybe the wiring? car is a 98 z28 w/ 95k m6.
thanks
josh
Old Mar 12, 2006 | 04:59 PM
josh1107's Avatar
anyone?
Old Mar 31, 2006 | 09:58 AM
1FSTLS1's Avatar
Does it seem to happen only when the car is started on a cold day? Mine seem to spit out SES when I start it on cold days.
Old Mar 31, 2006 | 04:38 PM
josh1107's Avatar
no, it happens more once ive been driving for 10-15 miles. but it makes me feel better that other people get the light with nothing wrong.
Old Apr 12, 2006 | 07:51 AM
josh1107's Avatar
my car keeps spitting out ses codes for the 02 sensor, even after i replace them. please help!
Old Apr 12, 2006 | 07:57 AM
NXZ28's Avatar
Do you put a bigger cam in the motor? Mine started doing the same when I installed the MS3. I think it is because it threw off the MAP sensor with the low manifold pressure. It seems to kill the same 02 sensor in a matter of a few weeks. I need a tune bad.
Old Apr 12, 2006 | 10:25 AM
josh1107's Avatar
nope, stock as far as i know, no tune
Old Apr 15, 2006 | 04:21 PM
josh1107's Avatar
replaced both front 02 sensors, still getting bank 2 sensor one slow response.
please help!!!
Old Apr 15, 2006 | 04:33 PM
brad8266's Avatar
Check wiring to make sure it isnt damaged or melted. You also could have damaged the new sensor upon install. Did you bang it on anything or get anything on it?
You did reset the PCM after you replaced it right?
Old Apr 15, 2006 | 10:25 PM
josh1107's Avatar
lol, yeah i reset the pcm. i just yanked out the o2 sensor, and it was covered in black sooty stuff. i put a new one in, hopefully ill have better luck. also replaced the fuel filter. i checked as much wiring as i could, nothing i could see.
thanks
josh
