Does this sound right?(Scanmaster numbers)
At the top of 3rd towards the end of the track I had a steady 2.3-2.5 degrees of knock retard. Also my highest O2mv reading was 901. Isn't that a bit rich?
Let me know if that's ok to run with, thanks!
901mv on the O2s for narrowband is also too low.... (too lean)
narrowbands are innacurate... but several years ago when I tuned based on narrowbands.... I looked for .930+
but regardless.. real performance can not be based on narrowband sensors...
You need to get a wideband sensor... and you're experiencing WAY too much knock....
w/out a wideband... I wouldn't go WOT anymore if it were my car...
So that's much knock is too much eh? ****. Oh well, time to have my tuning guy look at it again. Could it have just been a case of bad gas? I think he has either 31 or 32 degrees of timing at the top of 3rd but I can't remember.
Anything else to look for?
thanks for your response
Back the timing off and richen up the WOT and your car will be faster. And did anyone mention, get a WBO2?
