Stock Cats Question
Old Mar 15, 2006 | 01:17 AM
BigBenz's Avatar
Default Stock Cats Question
How often do the stock cats go bad? My car has 59k on it and im getting a O2 code ses light. car has lid and hooker cat back with a cut out. The ses light goes off and on when ever it feels like. gonna try to fix it this week end.
2000 z28.
any help would be great
thanks
Also i have the cut out open. Could open exaust at the y pipe send a code? the cut out is after the cats on the 3" after market y pipe the cats are about 2 1/2 feet from the open cutout.
Old Mar 15, 2006 | 07:06 PM
Cal's Avatar
Cal
If it's getting an O2 SES, why not replace the O2? Stock cats last a long time unless you have disabled the cat protection in the PCM firmware.
I think the cutout could be the problem also; fresh air can get sucked in and hit the O2s. Maybe someone with a cutout could verify that.
Old Mar 15, 2006 | 08:30 PM
Blacker's Avatar
Stock cats should last a long time. Of course, modding can shorten the life. The cutout should be far enough away for the O2 sensors to allow them to work correctly. Have you scanned the car to determine what the code actually is?
Old Mar 15, 2006 | 08:34 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
..Mine had 80,000 miles b/4 i took mine off and they were still fine.......
Old Mar 15, 2006 | 10:02 PM
89Formulaws6's Avatar
if its the post cat why not get a 02 sim? i am sure its cheaper then the real o2
Old Mar 15, 2006 | 10:06 PM
horist's Avatar
if it's precat then not Cat related
Assuming post cat, I would swap the sensors and see if the code follows... if it does it's the sensor
If it doesn't follow it's the cat ... there is I believe an 8year/80k mile warranty on emissions parts so may wanna see if you can get a dealer to hook you up... (though take off your aftermarket goodies just in case)
Old Mar 16, 2006 | 07:20 PM
DD87LS1's Avatar
Usually if the cat gets broken up inside itll put out a P0420 code a low cat efficiency code.
