HPtuners and the LM-1
http://www.hptuners.com/forum/showthread.php?t=5059
I'm about to go to bed, but there's lots of discussion in the help section of HPTuners forums that describes ways to optimize the wideband readings... but the first link shows the pinouts
There has always been about a .4 difference between what my LM-1 is reading as opposed to what's showing up on my laptop. Perhaps I have a ground issue?? I just hooked up the ground from the LM-1 to the ground on the EIO. So it is advised to find a grounding point in the vehicle and run a jumper to that point from the EIO and LM-1? The LM-1 has a single analog output jack and doesn't have the block wiring labeled the way it is in the HPtuners instructions for the LC-1.
Thanks for the patience with my questions.
