what is the best way to tune with wide band???
i am trying to dial in ve table using wide band. i realize speed density mode is a good start, but i have also heard of such things like open loop and closed loop speed density. what method would be best for my setup. i am tunning a supercharged car running 12 lbs of boost on a 383 stroker. let me know what you think.
ed
ed
Some people choose Open Loop SD cause there are less variables to worry about. Other use Close Loop SD this is typically where you drive your car at. In the end, I guess it's all about preference. I'm sure someone will chime in with a more informative perspective.
If you are running FI you will need to run open loop after about 80kpa and throughout your boost range. You can probably run closed loop up to that point fine.
Anything other than stoich is open loop controlled. (anything not using o2 for feedback)
ed
ed
- set PE table where you desire the AFR to be in PE mode
- tune VE table in SD/OL mode
- tune MAF table in OL mode
- tweak MAF table in CL mode as needed (if you did everything correctly beforehand this should be very little work)
- tweak timing tables
I personally think it is important to tune in OL for the first two steps for the simple reason that while the MAF may go out on you an O2 sensor may go out on you as well and send you into OL mode. If you have a high $$ engine you will have given yourself a very reasonable safety net in the worst case scenario.
Tim
