any way to lose a tune?
Old Mar 23, 2006 | 10:00 AM
00formLs1's Avatar
Default any way to lose a tune?
can you lose a tune by disconnecting the battery. or anything like that.
Old Mar 23, 2006 | 10:03 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Nope. You can leave the battery disconnected for as long as you want, and the tune will stay. If you are running a closed loop tune, it will lose any learned values (like your fuel trims), but those will be relearned in a short amount of time.
Old Mar 23, 2006 | 10:06 AM
00formLs1's Avatar
thanks, i was afraid it might reset the pcm to stock.
Old Mar 23, 2006 | 10:09 AM
MeentSS02's Avatar
It is a valid concern...tunes ain't cheap
Old Mar 23, 2006 | 10:31 AM
horist's Avatar
This is also addressed in the forum stickies
https://ls1tech.com/forums/pcm-diagnostics-tuning/287094-read-me-first-tuning-docs-ve-maf-ses-lights-faqs-more-01-31-07-a.html
Old Mar 23, 2006 | 10:32 AM
MeentSS02's Avatar
Stickies...what are those?!?
Old Mar 23, 2006 | 11:10 AM
Minion's Avatar
It's kinda obvious, but I'll point out one way to lose a tune is if the dealer (or some other service tech) reprograms it. In some cases people have lost expensive custom tunes when the dealer erased them without permission.
Old Mar 23, 2006 | 11:22 AM
ls1mongrel's Avatar
Never take it to a dealer if you have a custom tune, they wil most likly flash it and you will lose everything , it happen to a buddy of mine, 500 bucks down the drain !
