A4 running force motor off MAP?
Thanks!
Calculated engine torque is computed from airmass which is influenced by VE table (in SD mode) and also by RPM, MAP, IAT, ECT (i.e. it is not influenced by MAF alone or MAP alone).
So as long as your VE table is good, then your calculated engine torque should be good, and so your force motor current should be good; you should be good to go.
In SD mode, the PCM derives DYNAIR from the VE table (using RPM, MAP, IAT, ECT...).
Log DYNAIR, Delivered Engine Torque, Force Motor Pressure and Current, and verify that the engine torque is tracking DYNAIR, and that the TFMPRS pressure tracks engine torque.
