A few ??'s, VE, PE, IFR
If airflow hasn't changed (cams, cold air intake, etc.) then MAF should be OK.
An example is a large cam, which can cause an inversion of air (reversal) during idle. The MAF will see this, but it doesn't know which way the air is going
GM spent lots of time making a stock calibration that would be safe under many different situations... but safe != power....
I log for LTFT, STFT and MAP
I average LTFT and STFT, put the results included MAP values in a pivot table (excel) and so I can figure out a new IFR curve.
It's not a straight line as in the original table, it has a couple of bumps.
So far (in my case) the best result ever.
Maf in G/sec (if your MAF is correct)
Edit is not too bad, it just needs you to calculate the tables by yourself.
Excel is a good tool for that, but you know what you are doing.
I don't know OBD-2.com, I use Atap (antiquate but still fine - at least for my needs)
I didnt know about the formula i needed to use. Not sure I need the excel file, but wouldnt mind taking a look at one somebody made already. I guess I could always make my own.
tici, thankyou for the info. now I can tune!
IFR is a fixed table based on injector flow, nothing else. You set it irrespective of engine or modifications. Its the VE table that maps out the efficiency of the engine and hence how much fuel should be injected at each load point, thats why you should tune VE.
If you do anything else you are tuning with the aliens.
