idle tuneing issues
Old Mar 26, 2006 | 12:46 PM
edstrokedta's Avatar
Default idle tuneing issues
ok my set up consists of a 383 srtoker, d1sc @12 lbs, wide band, ls1edit, etc. i have been tunning car in open loop speed density and part throtle and wot are great. idle on the other hand stays around 500 rpms and is running 11 a/f. i have decreased values in ve table numerous times seeing no change in a/f at all. do i need to go to a different table to tune idle? any info would be appreciated. thanks..
ed
Old Mar 27, 2006 | 08:28 AM
white2001s10's Avatar
Are you working in the primary or the back-up VE table?
There's a ton of tables for idle, including fueling and tuning.
I know my old version of Edit didn't show any of that and all I could adjust was idle speed. Now I use EFI-live and it shows a ton more of usefull tables.
Maybe you just cannot get to what you need.
Old Mar 27, 2006 | 08:50 AM
The Primary Ve Is What I Am Using
Old Mar 27, 2006 | 09:45 AM
SMOKINV8's Avatar
Any time you're tuning VE, you need to make changes in the primary VE, then copy those changes over to the secondary or you won't see any difference. The computer runs off of the secondary VE table when the MAF is disconnected.
Old Mar 27, 2006 | 09:57 AM
Yep, I do my work in the secondary VE or backup VE table.
My idle is around the 12in/hg column.
Old Mar 27, 2006 | 12:11 PM
Thanks Guys I Will Try That And Let You Know.
Old Mar 28, 2006 | 08:33 AM
Used The Secondary Table And Fixed Idle. Thanks For The Help. But I Do Have Aquestion Though. How Come When I Made Changes To The Main Ve They Worked For Part Throttle And Not Idle?
Old Mar 28, 2006 | 08:44 AM
Don't know. I always work in the secondary table.
I guess it shouldn't have worked, but I haven't experimented with that.
Could you maybe make a big change there just to verify it happens?
Old Mar 28, 2006 | 11:58 AM
I Will Log For A While And See If Anything Changes Since Idle Is Correct Now.
