EFI LIve 2 step function
Old Mar 26, 2006 | 02:19 PM
80superbu's Avatar
Default EFI LIve 2 step function
I posted this on the EFI live forum but thought it may get more response here
I didn't realize until yesterday that there was a 2 step function on this program. Anyone here that uses it? I haven't bought EFI Live yet but I think this just saved me some money on a 2 step controller and/ or a transbrake.
Is it used just like an aftermarket controller and how would this work if I also drive the car on the street? would I have to go back in a turn it off..I guess?
Thanks
Old Mar 27, 2006 | 02:39 AM
cantdrv65's Avatar
Post
Yes it is a custom OS...But dont ask me for details Im a newbie with live...
Old Mar 27, 2006 | 08:30 AM
ace68's Avatar
it's a switch that you have to wire in and works in a custom tune so you will need the comercial version to install it. I have not used it yet but will try it this year. I was thinking about installing it last year but it was called a valet switch then now it can be used as a two step so tha's cool. I
Old Mar 27, 2006 | 07:50 PM
cantdrv65's Avatar
Post
Yeah you can also use the same input for the nitrous custom OS the way I understand....
Old Mar 27, 2006 | 08:20 PM
80superbu's Avatar
This was posted by Ross on the EFI website
Problem is, it uses the factory fuel cut routine, not spark cut, so no staging duels as it leans out pretty bad.
loks like it may not be right for a racing setup
Old Mar 29, 2006 | 08:00 AM
Fran D's Avatar
Well...the fuel is turned off to the cylinder, so there would be no combustion. Unless someone has figured out how to ignite air, leanness would not enter into it. It'd just be a wasted spark.
Remember, an SI combustion requires air, fuel and spark. Take away one, and you're left with... the other two.
Old Apr 25, 2006 | 11:39 AM
TPY2KWS6's Avatar
Anymore info on this?
Old Apr 25, 2006 | 11:47 AM
MrDude_1's Avatar
no fuel = no burn in the exhaust... no burn = slower/less turbo spooling...
with a conventional 2step, the fuel ends up burning in the exhaust, so the volume in the exhaust is still like WOT, keeping that turbo spooled up good..
this 2step only sounds like a solution for N/A guys.. mostly manuals, but i suppose someone with a large stall and a transbrake could use it to launch from a less then true stall RPM...
Old May 14, 2006 | 10:09 AM
SuperC1's Avatar
What's burning the fuel if there is no spark?
Old May 14, 2006 | 10:17 AM
SScam68's Avatar
The amount of cylinders that fire off are cut down to maintain a certain RPM, but every other one still does fire.
Old May 14, 2006 | 10:52 AM
SuperC1's Avatar
oh.. ok, thats sounds good, I guess.
Old Aug 17, 2010 | 05:35 PM
1999FirehawkLS1's Avatar
Would this wrk well on mt set up?...Mods in Sig
