Taking SD tuning to the next level....
Phil
I'm not exactly sure what you mean by VE throttle table... maybe something I've overlooked.
I did want to point out that if you mean when you say the idle dips, that the RPM drops and the MAP increases, then you could probably just catch the problem in your VE table by changing just that particular cell it drops to, to match your normal idle cell, and of course the spark advance would be duplicated as well to keep things more stable.
Anyway if the RPM does drop during your dip in idle, then you could possibly fix that area of the VE without harming your PT area.
I wouldn't think you could ever get to 800 RPM or less without having the throttle closed. I see more resolution for fixing the problem on the VE, but that's just me.
Hell, I don't know. Either way, it is a tough problem that I simply don't have, so pure conjecture is the best I can come up with.
Sounds like it may work really well for increasing your PT resolution.
Tune VE @ 800 and 1200 to 14.7
- will take care of any dips in idle, dips now in idle command 13.0:1 A/F which is tough for a big cam to recover from....
Use TPS to correct A/F to 13.x for PT.
Idle won't go rich if it stumbles and will add fuel for PT to WOT transition...
0 - 75% would command 1.00 and 75% to 100 would multiply the VE by 1.13
Phil, about your idle with the huge cam...
Consider that a big cam will pass a lot of oxygen out the exhaust even when the A/F is very good while burning in the chamber. This means your ideal A/F as reported by your wideband in the exhaust will actually be leaner than 14.7 as you see it displayed.
I would try something closer to 15.5 AFR as displayed by your WBO2 and you'll have some more room to cushion those dips. It may clean your idle up a bit.
I'm not sure what kind of advance you run in idle mode, but big cams generally like a lot. Something over 30* wouldn't surprise me at all with your size cam.
If the idle cleans up enough you may be able to drop it closer to 800.
