Trouble starting, staying above idle, dying in and out
I've been having this problem for a couple weeks now.
Sometimes, not all the time, just sometimes...the car will start, but then refuse to hold idle. It will drop to about 300rpm, surge to 600, and go back and forth and refuse to idle. Other times, it starts just fine.
A week after that started, I got an SES light. P0135, O2 sensor Bank 1 Sensor 1. Didn't really affect driveability.
Now I notice that when the car is doing its surging issues, it clears the code (which comes back after a couple starts again). So this leads me to believe its a battery issue.
Then yesterday, while accelerating decently hard down the road, the car's electrical system cut in and out. Everything- lights, engine, everything. The car would turn off and back on again within a fraction of a second, did that about 7 or 8 times, then ran fine after I turned it off and restarted on the fly. This also, naturally, cleared the code again.
I'm kinda at a loss. Is my battery bad? The terminals are clean and properly connected. What could it be?
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Don't forget about the infamous battery tray nubbin' that brakes off really easily on these cars. I have personally seen 3 cars including my own that had this problem. When you go WOT the battery slides into the A/C accumulator and the Pos lead shorts, cutting all power till you let off and the batt slides back. Check the battery for being secure and look at the accumulator for arcing signs. Simple stuff first.
STF veteran / 10 second club
Yup, I had a similar problem and it turned out to be a large power wire that was shorting against the headers ... turned everything in the car on and off and made the car surge all over the place when it happened. Just look around your headers to see if any wires are being burnt and shorting ... makes it really easy to see if you can do it at night.
You could definately have a bad O2 sensor as well ... both problems working together might be causing your issue.
