just going to give up on lc-1
Originally Posted by Black02SS
There is no reason to use Logworks. Regardless of if you use HPT or EFILive. Make a map/histogram in either program that shows the average of your 0-5v input from the wideband. Basically you are using the program as a multimeter. After you do this you can see in HPT exactly what the voltage it is reading and compare that to your actual voltage that you have set it to. If you have set the flatline voltage to .5 volts and you see .480 in EFILive/HPT, then you need to use .480 as your starting voltage instead of .5 The same will apply to any other voltage that you set in LogProgrammer. If you set a flatline voltage to 4.5 and see 4.492, then you will use 4.492. So you then will make a calculated formula that can be used as a custom PID. You may do this in excel to fine the slope and correct formula.
Example:
Programed outputs is
.5=10
4.5=20
You see
.490
4.489
Use these values as your formula
.490=10
4.489=20
I guarantee you that you will have a perfect formula if you do it as I have stated. I have done this on countless cars/widebands and it always comes up perfect.
Example:
.5=10
4.5=20
You see
.490
4.489
.490=10
4.489=20
0.5=7.35
0.5=22.39
Ave:1.002
1=7.35
1=22.39
Ave:1.83
1.5=7.35
1.5=22.39
Ave: 2.68
2=7.35
2=22.39
Ave:3.48
2.5=7.35
2.5=22.39
Ave: 4.28
3=7.35
3=22.39
Ave:4.917
3.5=7.35
3.5=22.39
Ave:4.917
4=7.35
4=22.39
Ave:4.917
4.5=7.35
4.5=22.39
Ave:4.917
What the hell is wrong? This is through HPtuners raw voltage.
If the sensor is bad, what is a replacement part number I can get from a GM dealer?
Originally Posted by 99whitews6
I am in the same boat. LC-1 is reading high voltages(AFRs) using HPtuners, I can connect to LM Programmer (and reprogram which I did) but I CANT connect to Logworks to determine my ground offset voltage. Its really starting to **** me off.
Oh yeah, and Klaus has stopped trying to help me over on the innovate forum.
Not selling anyways...I need to figure this POS out.
http://efiforum.iqd.co.nz/showthread...highlight=lc-1
You are on the right track. Now we just need to see where you are losing the voltage at.
The bosch O2 is a factory part on some VWs. Do a search for the PN.
How is your LC-1 wired to your car...?
Does the LED stop flashing...?
Have you ever accidentally shorted the brown or yellow wires to ground or power or anything...?
Originally Posted by muncie21
Read the values directly with Logworks, that reads the value digitally directly from the LC-1 unit. I'm pretty sure your problem is with the configuration in HPT.
I did finally get logworks to work, but how do I measure raw voltage? When It connects it just starts logging. I dont even know how to export to excel or log soley raw voltage?
Ok here is how I have it hooked up:
LC1:
- Red to auxilary power coming off battery positive.
- Blue Heater ground to chassis ground which is connected to the little black cable coming off the battery negative.
- Metallic System ground to Hptuners EIO black ground
- Brown Analog Out 2 to EIO input 1 white
- Yellow is sealed off and connected to nothing
- Black goes directly through an led and connects to the EIO ground black
Light blinks as should during warm up and then goes steady after warm up.
Did I hook up something wrong?
#32
Already ordered a new sensor, so I guess I will have an extra! LOL
#33
Sounds like you have version 1.x of Logworks. Download the newer 2.x version. I think there's a check box to display the readings in AFR or volts. If you read the WB with Logworks it is the value coming directly from the sensor. All the analog grounds (except blue heater ground) are taken out of the equation
#35
Can you guys not see the raw voltage in HPT? This is a 5min process. If you can see the raw voltage in HPT then I don't understand why you are using log works.
#37
Yep, I posted my raw voltage a couple posts ago which is why you mentioned I have a grounding issues or losing voltage somewhere. How the heck does someone go about troubleshooting where they are loosing this voltage?
#38
Originally Posted by oange ss
i dont know if it hurts anything but the cal wire should go to a chassis ground not to the EIO
Black should not be grounded (this is the calibration wire, grounding this causes the LC-1 to calibrate);
First, remove the black wire from ground and measure voltage again (looking for 2.5V at EXT.AD2).
Then, if it's still not right, remove the white wire from ground.
Do you have the LED connected between white and black...?
If you do, the LED flashing without pausing means the LC-1 is calibrating.
I have my white and green not grounded:
I use green as the "floating ground" for the NBO2 connection,
and white as the "floating ground" for the EXT.AD2 connection.
#39
I would double check all your wires. You aren't the only one with this problem as I have seen countless threads lately about HPT and Innovate widebands being off. I do not think it is HPT, I think it is the wideband. Did you read the link I posted? If you have a IM program of some sort, I would be glad to help you out and then maybe you can inform people that logworks isn't necessary.
I am on!
#40
-With the car OFF
-Key in run position
-Hptuners logging raw voltage
-Approx 0.757 with no power to LC-1
-Then connect power to LC-1 and while it warms up it reads a steady 1.95-2.04 volts
-Then it finishes warming up, led goes steady and voltage ALWAYS goes to 4.917-4.927(as long as I configure the wires for it to warm up with no error, no matter how I have the grounds)
