Stalling while turning.
We (the wife and I) just had our A4 car SD tuned with a Cam (MTI X1) and a Torque Converter (3400/2.2).
The problem we are having is the car is stalling when the power steering pump is being used near the stop, while turning near idle, or going into reverse. Also some surging issues if you give it a little gas off of idle.
The tune was done by a reputable shop, that offers retunes, but I have started hearing bad things about the quality of their work... I am even considering paying another $400 to take it to another shop to get tuned because the wife has had a major turn of opinion regarding our original tuner.
I know I should just go back to the original tuner, and have them look into it, that is the cheapest most straightforward solution; and they already have an initial tune on the car and should know it (even if it is crappy)... The car put down decent numbers on the dyno so that is not an issue.
Anyway, the reason I am posting this is for ideas of what may be wrong with the tune to bring to the tuner.
EDIT: The car idles fine in gear at a stop light or sitting still, just when turning (parking spots, car port spot) does it stall. The car also runs like a raped ape with any throttle. I was just thinking maybe the idle needs to be a little higher. The car idles around ~850 rpm when warm.
This has helped my idle settle down. Mine used to be exactly the same as yours. It sounds tough but its annoying.
Your idle should be around 825-875 rpms.
If I were you, I'd call them up or go there and explain everything, give them 1 more time to fix it since they are a "good" shop. It might be a simple fix that got past them.
Bill
The running airflow and timing and raising the idle a touch are key for a cam, but giving the cam the air it needs will probably help a lot too even with the tune that's in there.
If you adjust it too far you will get a slow return to idle when you stop and a "cruise control" effect, just back the adustment screw off again if this happens.
Rob (Bad30th)
sounds to me like you need to adjust the accessory airflow tables. FWIW, AC has its own set of tables.
As an idle test, while parked, turn on the head lights, turn the wheel, turn on the rear defroster, and turn the heater on full blast as close to the same time as possible. if the car stalls, you can bet it will on the street too.
Bill
We requested to be tuned in SD mode because I had heard that it is actually easier to tune out the problems we are actually experiencing (surging, stalling) with out the MAF, and with the standard temperature hardly ever getting in the freezing, I figured replacing the MAF with a piece of Fernco would open up our intake a little. Everything I had read basically pointed us to SD tuning even with our mid-sized cam. Like I said under throttle the car runs like a raped ape, and made fairly decent numbers for a stalled auto.
Regardless, the wife loves our car (as it was actually bought as her car), and I daily drive it to work (because of my commute the car gets better gas mileage than our pick-up truck). Whenever we go anywhere the Camaro is our method of transport. So really it was my decision to ask for the SD tuning, so that these issues would not arise. I love the sound of the car at ~850-875, it lopes hard!
I seem to be figuring the car out a little easier than the wife, because I drive it more; but still it is frustrating to be in the middle of a U-Turn and have the car stall in the middle of the intersection, or even just pulling into a parking lot to park! I don't have a tuning package, and really can not afford one. I paid $450, and rental car fees to have it done right, and would just like to get what I paid for. The reason I posted on here is for the shear wealth of knowledge and experience to help me with suggestions on what I should expect our tuner to address or ask about.
We sincerely appreciate everyone's help!
I use CFC QD Electronic Cleaner for this, and I think CFC MAF Cleaner will also work.
Someone suggested trying it with the ac on, rear defroster on, lights all on, stereo on, and heck even the wipers were going, and the car still idled fine... It is only when turning that it has a problem.(!?!?)
If you feel froggy, take the belt off and go for a quick spin around the block. Careful not to overheat the car !
Rob (Bad30th)
By the way, I'm no tuning expert but I did stay at a Holiday Inn Express last night.
Rob (Bad30th)
i check to make sure the bolt didnt back out the crank and it was still in there nice and tight. Azrael - rather than spend another $450 with the same or different shop, why not just buy your own tuning software?
