HPT 2 or 3 bar setup?
Old Apr 5, 2006 | 07:12 PM
Tiago's Avatar
Default HPT 2 or 3 bar setup?
I have been looking but can't find, and also having conflicting answers from different people. Basically 2 bar map should only read ~14.7 psi of boost, but some people have been trying to pursuade me that the HPT 2 bar setup is good for ~20?
is this true?
If not, then I need the 3 bar setup .
thanks,
Old Apr 5, 2006 | 07:16 PM
NYSS Guy's Avatar
the 2 bar setup only allows tuning up to 210 kpa, which would be 14.7 psi. I guess you could just set the fuel at the highest level to accomodate higher boost levels, but you'd run rich until you hit your final boost level. Hope that helps.
Old Apr 6, 2006 | 08:15 AM
Tiago's Avatar
Thats what I thought.
Now the question becomes, how to run 3 bar on a 99 pcm? Will it be ok to reflash it with 2000 software to support the 3bar or are there implications?
Old Apr 6, 2006 | 08:20 AM
foff667's Avatar
LS1TECH Sponsor
funny you ask that...i just sent an email to keith about that last night cuz i noticed I couldnt apply 3 bar to the 99 OS's I had on file. Not sure what you'd have to do in that case...if its as easy as just grabbing a stock 00+ OS & modifying it & plopping it in or what.
Old Apr 6, 2006 | 08:41 AM
Tiago's Avatar
that was my understanding, but hopefully someone can confirm
Old Apr 6, 2006 | 01:03 PM
Magnus's Avatar
LS1TECH Sponsor
Tiago, what OS are you currently running?
Old Apr 6, 2006 | 01:09 PM
Tiago's Avatar
stock 99 right now, will need to reflash with a 2000 OS to support your 3 bar SD addition correct? Any implications with this?
thanks,
Old Apr 6, 2006 | 01:47 PM
ESR's Avatar
ESR
LS1TECH Sponsor
Default .....
I think we can just use my 2000 file tiago we have licenses for all the years so we should be able to just load it. The PCMS for the 99-02 are all the same and 99,00 are the same. Magnus clarification please. This is being done with Conleys software which has all the years with the II and III bar options.
thanks,
Old Apr 6, 2006 | 02:01 PM
foff667's Avatar
LS1TECH Sponsor
I cant see it being a problem...the only thing you'd run into with hpt is you'd loose your vin # otherwise it would break their licensing style.
Old Apr 6, 2006 | 02:15 PM
ESR's Avatar
ESR
LS1TECH Sponsor
I believe you can edit the vin that should not be a big deal. Dont quote me on that but I believe the option is there. I have not had to edit a vin yet so that why I cant say for certain. I guess there is a first time for everything.
Old Apr 6, 2006 | 02:20 PM
foff667's Avatar
LS1TECH Sponsor
from what i know the vin must match the year/model of the new OS
Old Apr 6, 2006 | 02:37 PM
LSs1Power's Avatar
So if someone is running a 2 bar SD tune and passed 14.7psi to lets say 16psi he would need to add fuel via PE vs RPM?
Old Apr 6, 2006 | 02:41 PM
foff667's Avatar
LS1TECH Sponsor
or upgrade to a 3 bar OS...but yes add fuel via pe vs. rpm if you dont want to or dont have the means to upgrade.
Old Apr 6, 2006 | 02:44 PM
LSs1Power's Avatar
Isnt tunning a 3 bar harder than a 2 bar? Im asking because if its the same i might as well just get a 3 bar sensor now even though im running under 15psi so in the future when i run more than 15psi i dont need to tune again.
Old Apr 6, 2006 | 02:48 PM
foff667's Avatar
LS1TECH Sponsor
same tables & such so cant see it being much if at all different.
Old Apr 6, 2006 | 04:10 PM
DanaliHD's Avatar
is there a direct replacement 3 bar map sensor available? anyone have the part number?
Old Apr 6, 2006 | 04:15 PM
foff667's Avatar
LS1TECH Sponsor
http://www.hptuners.com/forum/showth...&highlight=bar
Old Apr 6, 2006 | 05:53 PM
DanaliHD's Avatar
anyone have a picture of what that harness etc looks like installed?
i just bought the sd upgrade today and ordered the 2 bar sensor from gmpartsdirect. the friggin dealership didn't have any and they were like $80.
Old May 1, 2006 | 07:19 PM
SStolen's Avatar
AutoZone.com carries MAP sensors. They have four different kinds:
2-Bar MAP sensor (Stock style) $40.99 2312
3-Bar MAP Sensor (Stock style) $53.99 PN 2313
2-Bar MAP sensor (MSD Controls) $60.99 23121
3-Bar MAP Sensor (MSD Controls) $60.99 23131
Will any of these work?
Old May 3, 2006 | 02:15 PM
WAHUSKER's Avatar
Summit carries all of those as well. I just ordered the 2312. Now I need to get the 2 Bar HPT upgrade.
