O/L SD tuning ?
Old Apr 9, 2006 | 11:25 AM
oange ss's Avatar
Default O/L SD tuning ?
should LTFT be showing in scanner during O/L SD tuning ?
Old Apr 9, 2006 | 11:28 AM
98redorangeta's Avatar
It can still be there it just souldent be doing any thing. LTFT has no control in open loop.
Old Apr 9, 2006 | 11:30 AM
oange ss's Avatar
as far a s i know they're not updating, my STFT aint showing I was wondering why the LFTF were...thanx for the help
Old Apr 9, 2006 | 11:34 AM
By not showing do you mean going to zero or not showing up on the scanner?
Old Apr 9, 2006 | 02:16 PM
Violatorno1's Avatar
You have to make sure the correct LTFT PID's are selected to view LTFT's. I kept mine enabled so I can see them while logging in SD.
Old Apr 9, 2006 | 06:37 PM
oange ss's Avatar
no numbers in scanner
Old Apr 9, 2006 | 06:57 PM
What scanner are you using? I know mine still show up in hpt scanner.
Old Apr 9, 2006 | 08:29 PM
BLK02WS6's Avatar
After you push your OL/SD tune in, but before you start logging, you also need to clear out the learned LTFTs or they will cause you to chase your tail for some time while you are trying to get the VE table right. It won't continue to learn, but the previously learned fuel trims will still effect the fueling even in OL.
Old Apr 9, 2006 | 08:33 PM
oange ss's Avatar
thanx for the tip
Old Apr 10, 2006 | 06:19 AM
DanaliHD's Avatar
so should you disable the ltft and stft and reset the fuel trims when running SD? I think I just read that on the hptuners forum.
Old Apr 10, 2006 | 08:31 AM
oange ss's Avatar
you shoulkd disable LTFT
Old Apr 10, 2006 | 09:00 AM
MeentSS02's Avatar
Kleeborp the Moderator™
You only have to disable the fuel trims when you are running in open loop...if you think about it, it should make sense to you that there should be no trimming, as you are taking away the only thing the computer uses for fueling feedback (the narrowband O2 sensors).
Old Apr 10, 2006 | 11:51 AM
DanaliHD's Avatar
In speed density mode, aren't you always in open loop?
Old Apr 10, 2006 | 11:59 AM
MeentSS02's Avatar
Not necessarily...open and closed loop has nothing to do with the MAF.
