Nooooooooooo!
Old Apr 11, 2006 | 02:31 PM
Homeslice (tm)'s Avatar
Originally Posted by stangkiller2005
sorry no disrespect.. but i smell bullshit
He heee
Old Apr 11, 2006 | 02:32 PM
98redorangeta's Avatar
You didnt happen to get gas right before your code was set did you or right before it went away?
Old Apr 11, 2006 | 02:57 PM
stangkiller2005's Avatar
naw... i got gas the day before.. i filled her up friday morning.. code came on saturday nite.. while racing...
Old Apr 11, 2006 | 04:20 PM
99whitews6's Avatar
Just an FYI:
I learned my lesson with the SES light. Cam sensor hi threw a code and SES light came on then went off, didnt think anything of it because it went off. Next trip it came back on and well...............now I have a 408!
Not saying its anything bad but from now on I make sure I KNOW exactly why the light came on even if it was just for 10 seconds!
Old Apr 11, 2006 | 05:21 PM
Originally Posted by 99whitews6
Just an FYI:
a friend was telling me that... his o2's have came loose before.. and he had to tighten them.. and it took care of the problem.. do u think this is a possibility? the car runs and idles fine... what i have noticed tho.. is at idle once the car has warmed up i get really low oil psi... when its cold its over 40 psi.. but when it warms up... at idle its at like 30 i think.. its ussual alil above the second line... and it wont drop from there.. but i still feel thats fairly low psi...
Old Apr 11, 2006 | 05:42 PM
SSpdDmon's Avatar
That's normal for oil pressure. Oil gets thicker as it gets colder...
Old Apr 12, 2006 | 01:10 AM
SmokingWS6's Avatar
Find another Autozone.
Old Apr 12, 2006 | 11:11 PM
Phillipm's Avatar
Instead of spending this time guessing at the problem just rent the darn tool so we can get this figured out!!
Old Apr 12, 2006 | 11:35 PM
Brock+2000Z28's Avatar
I think your car throwing the SES light was a warning. Your car is mocking you. You got beat by a Ford lighting and the car was saying, "Dude, you got beat ! Twice. Quit racing him. Just because you stomp down the pedal harder doesn't mean I go faster. Stop embaressing yourself !"
The car is asking for some nitrous. :d
No seriously, it's most likley something simple from one of the many sersors in the vehicle. If autozone won't do it for you, see if you can find an AAMCO transmission somewhere. They also do it for free.
As a general rule for myself, I am a pretty causous person, if I ever throw a SES and the car has been driven hard I do a minor tune up. Pull the spark plugs and take a close look at the oil. Not that this stuff will ever throw a fault code, these are things that can lead to other bad things that will throw codes.
Good luck and I hope it's nothing serious. And watch out for Lightings.
Old Apr 12, 2006 | 11:51 PM
thanx for the tip.. and i do plan on getting nitrous soon.. and im also getting heads,cam,and headers installed very soon... i just need retainers,pushrods, and an ls6 intake... and than my car goes under the knife!
o i didnt know amco would check them for free.. i have one around the corner.. ima go check them out this weekend...
o and do u think u could rub it in alil more bout the lightning lol... its not like i felt bad enough bout it already...
