Ok to leave increased tranny line pressure with Shift kit?
I just got done installing my transgo shift kit and now I want to drive it. Who has a shift kit installed and also has increased the line pressure via tune?
My problem is that my Hptuners interface went south so I can not remove all the increased line pressure changes that I made before I installed teh shift kit. WIll I be ok to drive it without removing the increased line pressures?
Thanks
Thanks
You should be ok as long as you stay out of the throttle. Line pressures shouldn't get to dangerous levels unless you start to put your foot into it. Still, the sooner you can fix the tune, the better.
Thanks
Thanks
Originally Posted by Transman
It will be ok to drive, although I would not drive like that for a long time. Excessive pressures cause transmission parts breakage and excessive wear on pump and sealing rings. No need for that. With the shift kit installed, you should retain your STOCK pressure settings.
