O2 Problem
Old Apr 12, 2006 | 09:02 AM
WhtFast01's Avatar
Default O2 Problem
Ok here is the story, I cant remeber what code it is but the description is Bank 1 sensor 2 slow to respond. I went ahead and replaced the O2 and resest everything with 20 miles the code is back. This all started happening after I put a Fast intake on the car.
Any Ideas?
Old Apr 12, 2006 | 10:07 AM
ringram's Avatar
Might just need a retune for the extra airflow. Maf cal might now be out.
Im guessing, but have you had it retuned?
Old Apr 12, 2006 | 01:28 PM
WhtFast01's Avatar
No I have not had it re-tunned since the Fast intake.
Old Apr 12, 2006 | 01:32 PM
SMOKINV8's Avatar
You might also check for vacuum leaks on the intake.
Old Apr 12, 2006 | 01:39 PM
2001NBMZ28's Avatar
Can you post the actual code? I thought "slow response" codes were for the precat sensors. Bank 1, sensor 2 would be the driver side postcat sensor. Which one did you replace?
Old Apr 12, 2006 | 02:16 PM
WhtFast01's Avatar
Sorry its the pre cat on the drivers side.
Old Apr 12, 2006 | 02:25 PM
WhtFast01's Avatar
but would that cause both O2 to have the same code?
Old Apr 14, 2006 | 08:57 AM
SMOKINV8's Avatar
More than likely, yes. Its easy to check for vacuum leaks though, just blow some smoke (or have a buddy do it if you don't smoke) around the edge of the intake while its running and see if it gets sucked into the motor somewhere.
Old Apr 15, 2006 | 07:57 AM
98Z28CobraKiller's Avatar
Restricted User
Is there a more accurate way to detect a vaccuun leak by scanning? Wouldn't throw off a table somewhere?
Old Apr 16, 2006 | 10:44 PM
fbirdserge00's Avatar
I had the same problem on mine, but mine said just "bank" which are the ones closer to the engine. The bank 2 are the ones furthest from the engine
