SD tune what would cause this?
Old Apr 13, 2006 | 03:33 PM
Kiss_My_99SS's Avatar
Default SD tune what would cause this?
I've got everthing set to sd tune. With the MAF removed the car will not run past idle. It will idle and thats all. Why?
Old Apr 13, 2006 | 03:40 PM
foff667's Avatar
LS1TECH Sponsor
post your bin so we can view your file...possible error in the file it what i would assume.
Old Apr 13, 2006 | 03:46 PM
I'll post it later. If it helps any my car is a 99 and I am running a 01 OS.
Old Apr 13, 2006 | 03:48 PM
foff667's Avatar
LS1TECH Sponsor
did you transfer all the stuff over from the 99 file to the 01? What software are you using?
Old Apr 13, 2006 | 03:51 PM
I transfered everthing over it took about 20 mins. I did notice that the firing order is different for 99 to 01. Which would I use? I'm using Hp tuners.
Old Apr 13, 2006 | 04:01 PM
70Stang's Avatar
huh??
Old Apr 13, 2006 | 05:06 PM
brad8266's Avatar
Originally Posted by 70Stang
huh??
yeah, huh?? Firing order should be the same.
Old Apr 13, 2006 | 09:51 PM
Open up a 99 bin file and a 01 and look at the firing order in engine diagnostics general.
Old Apr 14, 2006 | 12:08 AM
foff667's Avatar
LS1TECH Sponsor
your dianostic codes are setup as active & to not report an error so your basically telling the computer "yeah everythings just fine...maf is on and working well" when in reality the maf isnt even on the car...thats probably your problem...turn off the ses for the maf code and you should be ok.
Old Apr 14, 2006 | 12:24 AM
I set it to no mil light. I'll see if that works. Thanks
