Just shoot me! P0327 code AGAIN even after replacing knocks and harness
. AT this point I just want to
. I work 4 jobs, have basically no free time, I don't want to have to waste another 2-3 hrs pulling the intake etc...... to mess with the knocks. WTF is up with this.......... Anyone have any ideas? I thought I'd replace both knock sensors and the Harness to save the hassle in the future. Now I get more hassle. I got the LS6 harness b/c the stock LS1 harness had a hard time clearing the LS6 intake I put on.Please help!
I had this same problem as have others... wire gets pinched, rubs through and causes a sensor to look like it's dead... pulls tons of timing too (4* constant KR, plus always in low octane tables)
The harness clips into the main wiring harness in back of the block (you can reach it from the top w/the intake off)
I would pull the intake off and check continuity of the knock sensor wiring harness
ok will have to pull intake again! grrrrrrrr
hope I don't need another wiring harness if this one is already toast, 2days old from SDPC.
So you think it's the new harness got pinched etc....... I know I plugged it into the main wiring harness, any chance main harness is bad, it wires to PCM etc.... Not sure I'm using correct terms here. Just grasping as this is becoming an albatross. This crud, and now my clutch is sticking to floor every time I try WOT runs
. When I had the problem, I was setting P0327... right after installing my LS6 lifter valley and intake... got the code right away... ****... so I ignored it.. went to the track and raced... lost over 1 second due to pulled timing! yikes!
so when i got home, replaced both knock sensors, didn't notice the wire pinched
Replaced intake, still there! fudge!
took the intake off again (byt his time it was like a 15 minute job heh) and searched around more and there it was...
Now whenever I have the intake off, I use a couple small pieces of masking tape to hold the wire where I want it during intake reinstall...
What you can do is unhook the knock sensor harness... use an ohm meter to test continuity for each wire
then you can do the same from the main harness to the wire on the PCM, see if it has continuity or if there's a break somewhere
I have heard of people repairing them also
I'm about 1.5 hours east of you near Barrington/Lake Zurich/Wauconda area
