Open loop PE?
Old Apr 17, 2006 | 08:55 AM
Sotiri's Avatar
Default Open loop PE?
Is POWER ENRICHMENT used in open loop? I'm sure it is... But i want to make sure before i disable it and put the pedal to the metal.
Old Apr 17, 2006 | 09:07 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Yes it is...it (the PCM) picks the richer of the values from the Open Loop F/A table and the PE table.
MeentSS02's Avatar
So just make sure one place or the other is rich enough should you floor it while tuning.
Old Apr 17, 2006 | 09:42 AM
Sotiri's Avatar
PE for coolant temp is to add 15% fuel and PE for RPM is to add 0% to 8%. These would make sense for a AFR start-off point of 14.7. But if the open loop at 100 MAP is 12.9, it would be too rich. But I guess you make sense
Old Apr 17, 2006 | 10:02 AM
MeentSS02's Avatar
Glad someone did, because I didn't understand a word you just wrote
Old Apr 17, 2006 | 10:38 AM
chrisj6's Avatar
I understood open loop and PE
Old Apr 17, 2006 | 02:23 PM
GuitsBoy's Avatar
You are technically in open loop mode, since the o2 data is thrown out.
The computer takes its fueling values from whichever is richer: The OLFA table (x-referenced by ECT & MAP) or PE (x-referenced by RPM). I have my OLFA table set to all 1.00's from 178* on up, that way WOT always gets it fueling from PE.
Old Apr 17, 2006 | 02:30 PM
MeentSS02's Avatar
Same here, only I set 95-105 KPa on the OLFA table to 1.1 just in case PE is being too slow
