P1637 Generator L-Terminal Circuit HELP!!!
Old Apr 18, 2006 | 09:41 PM
Jpr5690's Avatar
Default P1637 Generator L-Terminal Circuit HELP!!!
Is This Code Almost Always Caused By A Failing Alternator?
There Isnt Much On This One But Eerything Ive Read Seems To Point To Alternators
Im Throwin This Code, My System Voltage Seems To Low (as In My Alternator Dosent Charge) And There Is A Annoying Squeek Comming From My Engine Bay ?
Im Thinking Alternator But Just Wanted To Get Your All Thoughts ....
Old Apr 18, 2006 | 10:28 PM
Dmoney's Avatar
It's that one wire that is on top of the alternator. Due to the stress of daily driving, that wire becomes stressed and will eventually break off or just get loose from the terminal. I had that problem and regret that I waited to long to get it fixed. I got my replacement at the dealership for about $35 bucks. The one they give you has 4 wires attached to the plug, just cut the other 3 you don't need and leave alot of slack to avoid the lack of slack from the original.
Old Apr 19, 2006 | 05:37 AM
Jpr5690's Avatar
cool.. i recently put in a new alternator and as of now it seems to me randomely turning on and off
also i did extend that wire but mabye its a bad connection.. i used a gauge wire for my extension could this be causing an impedance problem also i used a crimp to connect the two
Old Apr 20, 2006 | 07:52 AM
Jpr5690's Avatar
i checked it and no luck im still throwin that code and my alternator still has an irratic charging pattern (once it gets hot)
Old Feb 22, 2017 | 10:25 PM
BlueBird1999's Avatar
Had this same problem in mine. I changed the 4 pin connector on the top and got it fixed like Dmoney said
