2bar map sensor install and ?'sss
Old May 3, 2006 | 11:06 PM
Assassin's Avatar
Default 2bar map sensor install and ?'sss
well I somehow found a way to get the sensor changed w/out taking the manifold off, quite simple now that I know how, though my wrists hurt like heck, haha... well I changed the map sensor but havent loaded the 2bar hptuners file yet, still stock, I'm wondering if just that sensor will screw w/things if I dont have time to load the new program before tomorrow..?..
Old Jun 12, 2006 | 01:30 PM
blackbird345's Avatar
Can you disclose that method of getting the sensor out?
Old Jun 12, 2006 | 01:43 PM
SSpdDmon's Avatar
Sounds like a strong, flexible wrist is required.
Old Jun 12, 2006 | 02:08 PM
kbracing96's Avatar
you need to at least rescale your map sensor so you have the same kpa reading at key on engine off as you had before with the 1 bar, or the map will read really low.
Old Jun 12, 2006 | 03:57 PM
MECHAM's Avatar
i am running the 2 bar sensor without the 2bar program and it works fine.
didnt re-scale anything
Old Jun 12, 2006 | 06:51 PM
dc96819's Avatar
My truck wont start
Old Jun 12, 2006 | 08:17 PM
WS6FirebirdTA00's Avatar
dont run a 2 bar map on stock OS. If you are running a 2 bar map and it works fine on a stock OS that means you dont have a 2 bar map sensor. The fueling will be all weird since the MAP wont be read correctly.
Old Jun 13, 2006 | 01:03 AM
Mecham can you give us some more info on running the 2 bar sensor?
Old Jun 13, 2006 | 01:54 AM
Assassin's Avatar
wtf, this thread is old, now I'm getting replies, weird.... yeah so just changing the sensor messes things up, I was able to change the map w/out taking the manifold off, thank you y-body... I've had my 2bar sd tune going for a while now, its the best for tuning boosted engines.. check hptuners for more info, just cost extra $$ you didnt expect/want to spend but thats how everything goes right..
Old Jun 13, 2006 | 02:24 AM
MECHAM's Avatar
all i did was just put it in...im using the cobalt 2bar sensor.
here is what my scanner logs look like with it
http://flowerstechnology.net/Documents/1st.xls
the reason i didnt convert to the 2bar is because after i only put in the MAP just like the help file says...my ltrims change from slightly positive at idle to like -10.9 at idle...the car leaves black soot on the ground and runs like crap. this is leaving my PE vs RPM the same and having the PE vs BOOST at 1.00
i wont do the 2bar tune until i get my fuel pressure taken care of and my tuner has time. so im using his last tune with the sensor...no problems
also...does every1 else MAP settings underboost fluctuate like mine do?..u can see it peak...go down a little..back up or does every1 elses go to peak and hold that number??
Old Jun 13, 2006 | 08:38 AM
SSpdDmon's Avatar
Oh, c'mon guys. That was at least a little funny...
Old Jun 13, 2006 | 08:54 AM
SSpdDmon's Avatar
