What is the idael air fuel ratio???
I am not sure if this is the correct place to post this but I just want to know what is the best A/F for performance and normal driving? Right now I have just installed a LM-1 in my car and it is reading 14.8-15.5 at idle and part throttle and 13.8-15.2 at wot. Just want to know what is needed to get the most power out of the mods that are done to the car. BTW the car has Lt Headers and a TD exhaust with air lid and SLP ram air and intake. should the ratio be this high? Any and all help would be greatly helpful. Thank you
the pcm commands 14.68, now w/ Power Enrichment the AFR goes down to 11.0 -12.6, i have read hear on one of the stickies that ls1's develop max power at 12.8-13.0, and max torq at 12.3-12.5??? but that just what ive read
You might need to re-calibrate your WB, or use a smoothing function.
For WOT only:
Most cars like WOT to be around 13.0:1 but it depends on loading and RPM range as well.
A car that stays at high RPM with little load may like 13.5:1 or higher.
An example would be a 6-speed swap into a small lightweight vehicle like an RX7 or similar.
A more loaded vehicle with heavier weight and automatic transmission may prefer 12.8:1 or lower depending on RPM range. It seems many cars prefer to be a little richer at the torque peak and leaner after that, but that's not a rule.
For part throttle I prefer 15.5:1 and leaner, but you can't do that unless you run open-loop.
For WOT only:
