Nebie here, need info for setting LS1 in SD mode!
Old May 4, 2006 | 06:08 PM
makWS6's Avatar
Lightbulb Nebie here, need info for setting LS1 in SD mode!
I have a 01 WS6 cammed and I now need to tune my LTFT's I have Hptuners and checked out a thread how to and they told me wrong somehow. Here is the order in which I was told.
-Copy Low Octane table to High Octane table
-Go to Power Enrich and select HOT, next select cells from 0-7200 and replace values with 100.
-Re-write PCM, Unplug MAF
-Start up car(may idle wierd)
-On scanner choose VCM controls, select Fuel and Spark
-Start scanner
-select Reset Fuel Trims
-Drive minimum of 50 miles
Well I did all this and the damn car wouldn't keep idleing and and would choke if I touched the gas. I know something was wrong with how I was told to do this, could someone with know how please help and tell me the correct way! Many thanx!
Old May 5, 2006 | 09:06 AM
SSpdDmon's Avatar
Ummm...did you read the stickies? https://ls1tech.com/forums/pcm-diagnostics-tuning/287094-read-me-first-tuning-docs-ve-maf-ses-lights-faqs-more-01-31-07-a.html
Old May 5, 2006 | 09:25 AM
white2001s10's Avatar
-Start scanner
That's missing a couple of things for sure.
Old May 5, 2006 | 11:09 AM
makWS6's Avatar
Yeah that will help! thanx!
