po102
Old May 6, 2006 | 08:56 PM
Charlie@LsXperts's Avatar
Default po102
like it says..... po102 MAF low curcuit input. i had one of my 02 extensions burn yesterday and my ses light set last night, ran like crap... sputtered popped, no power and it would about burn your eyes standing next to it, but that is the code i threw. so today i put a new 02 sensor on and the symptoms went away but the ses light is still on. Could that bad 02 be what set off the MAF by chance?????
Old May 6, 2006 | 09:27 PM
why does nobody respond in this board?
Old May 6, 2006 | 09:40 PM
2xLS1's Avatar
Engine Sensor Fuse is probably popped. It sources 12V to the O2 sensors and the MAF.
Old May 6, 2006 | 09:43 PM
would that still allow it to set off the SES, Which fuse is that, what is it labeled
Old May 6, 2006 | 10:05 PM
Doc's Avatar
Doc
Yes, no pwr to the maf will set the code. Look under the hood in the fuse compartments.
Old May 7, 2006 | 08:45 PM
that was the problem....... Another question though, after i fixed it the check engine light stayed on and i went and cleared it. How long should it be if the problem isnt fixed for the light to come back on? wouldnt it be instant? i drove 5 miles from where i cleared it and it didnt come back on..... i was also throwin codes for the 02 heater curcuit, it comes and goes every once in a while what would cause it to come back and go away? bad wire?
